Pushrod Tube seals, viton seals |
AZBanks |
Jan 23 2021, 12:46 PM
Senior Member Group: Members Posts: 1,060 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
AZBanks |
Jan 23 2021, 12:52 PM
Used by FAT Performance, European Motor Works and the California Central Coast School of High Tech Stuff. But (IMG:style_emoticons/default/WTF.gif) do they know? (IMG:style_emoticons/default/av-943.gif) Thats interesting, is that the Locktite pipe sealant in the photo? No that is RTV... I think I'm going to cough....hack hack... BTW I use to use the Loctite pipe sealant, but I been using DOW 55 molycoat O'ring lube, which is a grease. Do you have a supplier and part number on the DOW 55? Nevermind, I had to try a bunch of search terms but finally found it. It is McMaster part number 1325K54 |
bbrock |
Jan 23 2021, 03:43 PM
Do you have a supplier and part number on the DOW 55? Nevermind, I had to try a bunch of search terms but finally found it. It is McMaster part number 1325K54 Found it cheaper on Amazon: https://www.amazon.com/Dow-Corning-Molykote...7927&sr=8-5 |
DRPHIL914 |
Jan 23 2021, 04:14 PM
i got my x shapes from Mcmark 3 years ago and installed them, no leaks since . |
AZBanks |
Jan 23 2021, 04:23 PM
Are the o-rings the same size for 1.7 and 1.8 liter engines?
AZBanks |
Jan 23 2021, 04:32 PM
Do you have a supplier and part number on the DOW 55? Nevermind, I had to try a bunch of search terms but finally found it. It is McMaster part number 1325K54 Oops, That part number comes back as: Seal and O-Ring Grease, Dupont Molykote 55, 5.3 oz. Tube It is listed as Dupont. Does anyone know if this is the same as the DOW? |
mark04usa |
Jan 23 2021, 05:17 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
Jan 23 2021, 10:02 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Lo-Fi Version | Time is now: 7th May 2024 - 08:31 AM |
