Muffler Options for T4 Header, Updated to SpinTech Muffler |
7TPorsh |
Jul 28 2015, 04:49 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Working out installing a msds T4 header and am considering muffler options. My first choice was to attach a flowmaster to the end of the collector and add a tail pipe....header exits on the driver's side.
It is turning out there may not be enough room since the header collector and reducer put the flange out near the end of the trans. I can route the pipe and muffler across the back and exit the passenger's side but then I need to change my valance. I think curving the pipe back to the driver's side will be tight; and hard to find a shop to spend the time. I remember seeing some kind of 911 muffler, banana type, that had the inlet and exit on the same side. Was that a custom job? Are they effective? Has anyone done this setup? How do you mount the muffler? |
Chris914n6 |
Jul 31 2015, 01:23 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
^^ Yes. Technically a repurposed section from a tire with holes punched in it. Never seem them before but evidently common, as a former Midas Muffler shop mechanic did it back in my RH days. He overruled my plan to use straps over the shield a'la 911.
First pic I found. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:05 PM |
