Muffler Options for T4 Header, Updated to SpinTech Muffler |
7TPorsh |
Jul 28 2015, 04:49 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Working out installing a msds T4 header and am considering muffler options. My first choice was to attach a flowmaster to the end of the collector and add a tail pipe....header exits on the driver's side.
It is turning out there may not be enough room since the header collector and reducer put the flange out near the end of the trans. I can route the pipe and muffler across the back and exit the passenger's side but then I need to change my valance. I think curving the pipe back to the driver's side will be tight; and hard to find a shop to spend the time. I remember seeing some kind of 911 muffler, banana type, that had the inlet and exit on the same side. Was that a custom job? Are they effective? Has anyone done this setup? How do you mount the muffler? |
Dave_Darling |
Jul 31 2015, 03:26 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If it gets hard connected, it must be to the transaxle, not the body! (Which includes the heat shield.) The whole drivetrain moves around, and if you solid mount the muffler to the body it will break the muffler, or the exhaust, or the exhaust studs. Something's gotta give, as they say.
The soft mount should support the weight of the muffler, but still allow it to move as the drivetrain moves. Hopefully it's good enough. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 06:08 PM |
