Most important pics, Buying first 914 |
Carl456 |
Jul 29 2015, 07:51 AM
Member Group: Members Posts: 54 Joined: 24-July 15 From: Southern Ontario Member No.: 18,990 Region Association: Canada |
First time poster.
Looking at purchasing a 914 but new to the whole process. My question is, before going to view a car, what are some of the most important HD pictures you like to see ("request") when looking at a used 914 online? Any specific angles? |
76-914 |
Jul 29 2015, 08:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Behind the rockers, jack points (beneath and sides), Hell Hole area beneath the battery, suspensions consoles, battery tray, floor area surrounding the pedal cluster, all 4 pans but especially where the rear most pans meet the rear firewall, behind the pad of the rear firewall, bottom of doors/sill plate areas, inside of door jambs, top of fender cowlings (close to windshield), behind the vinyl on the sail panels...................
montoya 73 2.0 |
Jul 29 2015, 03:38 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Below is a link to my blog on some pics I have collected from other members here.
Rust...where to look |
Cairo94507 |
Jul 29 2015, 05:34 PM
Michael Group: Members Posts: 9,776 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
You will really need to look under the entire car and look for rust or areas that appear to be recently painted or coated with underseal. Some sellers are devious and conceal damage and rust.
Use an ice pick or long pointed steel rod to poke and feel for rusted or soft metal. Look anywhere water can rest and collect. Look inside the trunks with the carpet removed so you can see the metal. Behind the seats, under the seats, the door jams, especially where the door latches as the area below that is prone to rust out. Also, with the top off and the doors open stand on the floor of the interior and jump and down a little and see if the car flexes. These cars can fold in half when badly rusted. Take a flashlight and look into the jack posts on the rockers below the doors in front of the rear wheels. Pull the black cap off if it is there and check it out. The entire engine compartment, especially on the passenger side below the battery and towards the firewall behind the seats. This is the "hell hole" and if the battery is still located in the stock position, when the car got wet and did not have a sealed battery, acid tended to run out and cause the metal to rust badly. It is not uncommon to look down and see the ground through the chassis due to the rust. Check all of the electrical to see if everything works - everything, even the cigarette lighter and interior light. These cars are a ton of fun but the rust monster can ruin your experience quickly. Aside from that it is all fixable. Don't be impulsive and snap up the first car you see. You need to see quite a few cars to know what you are looking at. Or if you take someone with you that knows these cars, terrific - you will be better informed when you find the one you want. |
Mike Bellis |
Jul 29 2015, 07:46 PM
iwanta914-6 |
Jul 30 2015, 07:17 AM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
All I can offer since I am also in the market, buy the best car you can afford! BUT, do it soon as prices are quickly escalating!
OR, if you have nothing but time and money, find something solid and restore it. |
EdwardBlume |
Jul 30 2015, 07:35 AM
Claus Graf |
Jul 30 2015, 08:59 AM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
Welcome to the forum.
When you find a car you're interested in, ask in the forum if somebody knows about the car or lives near and can go and check it out for you. Look out for longitudinal rust. Regards Claus Attached image(s) |
Lo-Fi Version | Time is now: 21st May 2024 - 10:29 PM |
