Melling M-79AHP Oil Pump |
#27GLA |
Jul 29 2015, 05:44 PM
Newbie Group: Members Posts: 7 Joined: 7-May 14 From: Michigan Member No.: 17,319 Region Association: None |
Anyone else using this oil pump on their Type IV engine and finding it leaks?
Having issues trying to get the cover plate to seal..... Cover plate was leak free prior to rebuild......mechanic cleaned up.....reused and installed with paper gasket and Permatex Aircraft grade sealant.....no leaks till I went to track and got black flagged.....excessive smoke from under car.......Took it a part.....resealed and still leaked in the shop Purchase new unit......sealed per instructions.....still leaks Called Melling Pump......they can't figure it out either but overnighting new gaskets of several styles.....Installed new gaskets per their directions....still leaks Going to Melling tomorrow as their manufacturing/RD is an hour away Besides Melling......what other High Volume pumps are available that are reliable Any use an O-ring to seal instead of a gasket |
Firstcar |
Jul 31 2015, 09:56 PM
Obsessive amateur mechanic Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
I think this has been "covered" elsewhere but the cover supplied with the Melling is a source of leaks - it flexes. I bought a type I cover from the Type IV store and it solved the problem. Applied Permatex 3H to case, gasket, and pump body. Applied Hylomar to cover gasket. Installed cover, Permatex 3H on studs, added wavy washers and torqued to 14.5 ft lbs. - no leaks.
Lo-Fi Version | Time is now: 17th May 2024 - 04:55 PM |
