ls to boxster S trans |
Stacks914 |
Jul 30 2015, 12:52 AM
Member Group: Members Posts: 183 Joined: 1-April 15 From: Omaha, ne Member No.: 18,582 Region Association: None |
Does anyone know of an inexpensive(imagine that) way to mate the LS engine to the boXster S trans?
Thanks in advance! |
mgp4591 |
Jul 30 2015, 12:57 AM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Does anyone know of an inexpensive(imagine that) way to mate the LS engine to the boXster S trans? Thanks in advance! Have you checked Kennedy Engineering for an adapter plate? Also I believe BIGKAT 83 was working on a similar setup but his may be a 6 spd. Someone around here is doing it- do a search and I'm sure you'll get lucky! |
Stacks914 |
Jul 30 2015, 04:45 AM
Yep checked with K.E.... Might just be experiencing sticker shock... Mine is a 6 as well it's the boxster S trans. Have a email into another guy. Any help would be appreciated.
BIGKAT_83 |
Jul 30 2015, 07:44 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Yep a little higher priced than the SBC adapters.
Mueller |
Jul 30 2015, 08:25 AM
And the price is?
Stacks914 |
Jul 30 2015, 01:17 PM
This is the email I got from K.E.
Our kit for the LS series engine to the '00 - '02 Boxster S is $1,800.00 USD (Adapter kit includes: Adapter plate, flywheel, pilot bearing and bolts) Our kits are designed to work with the factory LS starter or we have an after market starter for $235.00 Our kits are designed to work with the factory Boxster S clutch or we have our heavy duty clutch kit for $954.00 (Clutch Kits include: Pressure plate, disc, throw out bearing and bolts) eric@kitcarchassis.com has quoted me $1595 with clutch and everything plus adding 350 for an upgraded clutch to fit my hp aplication. Bigkat what adapter did you wind up going with? |
Mike Bellis |
Jul 30 2015, 09:21 PM
(IMG:style_emoticons/default/av-943.gif)
There is no way to add a Boxster S tranny cheap unless you go with an Audi motor. Then it's a direct bolt on. You coule always machine your own. That would be cheap(er)... |
Stacks914 |
Jul 31 2015, 01:34 AM
Can I turbo the Audi motor to 5-600hp.....I already got the 70mm turbo (IMG:style_emoticons/default/evilgrin.gif) But shit might look into it if it can be done cheap.... I need 500 hp At least
(IMG:style_emoticons/default/av-943.gif) There is no way to add a Boxster S tranny cheap unless you go with an Audi motor. Then it's a direct bolt on. You coule always machine your own. That would be cheap(er)... |
Stacks914 |
Jul 31 2015, 01:56 AM
Yea and I thought it would be $350 and you could use ls clutch. And yes while the money is rediculous once it is all said and done the LS motor would be a better and cheaper platform to,build excessive amounts of power. So really it's a minor hiccup. I am almost done working on this 75 I bought from a member and then it will be full speed ahead on the 72. Oh and yes the chassis will be stiffened and lugs/brakes upgraded
Mike Bellis |
Jul 31 2015, 10:33 PM
Can I turbo the Audi motor to 5-600hp.....I already got the 70mm turbo (IMG:style_emoticons/default/evilgrin.gif) But shit might look into it if it can be done cheap.... I need 500 hp At least (IMG:style_emoticons/default/av-943.gif) There is no way to add a Boxster S tranny cheap unless you go with an Audi motor. Then it's a direct bolt on. You coule always machine your own. That would be cheap(er)... An Audi 1.8L can put out 600+ HP. Imagine what you could do with a 4.2L V8 twin turbo... (IMG:style_emoticons/default/happy11.gif) |
Stacks914 |
Aug 6 2015, 03:33 AM
yea I was looking at the metal and that is not cheap! What was the build where the guy fabbed his own? Really you can spend 1800 on a clutch and flywheel for the engine and trans so the kit might not be all that bad. I already got the motor and the trans so I got to get the shit together.
Lo-Fi Version | Time is now: 26th April 2024 - 11:55 AM |
