ls to boxster S trans |
Stacks914 |
Jul 30 2015, 12:52 AM
Member Group: Members Posts: 183 Joined: 1-April 15 From: Omaha, ne Member No.: 18,582 Region Association: None |
Does anyone know of an inexpensive(imagine that) way to mate the LS engine to the boXster S trans?
Thanks in advance! |
Mike Bellis |
Jul 30 2015, 09:21 PM
(IMG:style_emoticons/default/av-943.gif)
There is no way to add a Boxster S tranny cheap unless you go with an Audi motor. Then it's a direct bolt on. You coule always machine your own. That would be cheap(er)... |
Stacks914 |
Jul 31 2015, 01:34 AM
Can I turbo the Audi motor to 5-600hp.....I already got the 70mm turbo (IMG:style_emoticons/default/evilgrin.gif) But shit might look into it if it can be done cheap.... I need 500 hp At least
(IMG:style_emoticons/default/av-943.gif) There is no way to add a Boxster S tranny cheap unless you go with an Audi motor. Then it's a direct bolt on. You coule always machine your own. That would be cheap(er)... |
Mike Bellis |
Jul 31 2015, 10:33 PM
Can I turbo the Audi motor to 5-600hp.....I already got the 70mm turbo (IMG:style_emoticons/default/evilgrin.gif) But shit might look into it if it can be done cheap.... I need 500 hp At least (IMG:style_emoticons/default/av-943.gif) There is no way to add a Boxster S tranny cheap unless you go with an Audi motor. Then it's a direct bolt on. You coule always machine your own. That would be cheap(er)... An Audi 1.8L can put out 600+ HP. Imagine what you could do with a 4.2L V8 twin turbo... (IMG:style_emoticons/default/happy11.gif) |
Stacks914 |
Aug 6 2015, 03:33 AM
yea I was looking at the metal and that is not cheap! What was the build where the guy fabbed his own? Really you can spend 1800 on a clutch and flywheel for the engine and trans so the kit might not be all that bad. I already got the motor and the trans so I got to get the shit together.
Lo-Fi Version | Time is now: 19th May 2024 - 10:22 AM |
