Repro Exterior Door Handles |
gms |
Jul 30 2015, 08:01 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
here are some pictures of the reproduction Exterior Door Handles sold by Pelican Parts. All in all the look pretty good for the price. I will hold final judgement for when I install them and use them for a while. Here are some pix
Mikey914 |
Jul 30 2015, 08:04 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'd be suspect of that door lock bushing. Looks like a straight piece of tube. I know these should have a step in them. From what I've seen of these the finish is not quite right. It's 95%. Looks like is pretty good, but they needed one more stage on the outer finish as you can see the machine marks if you look closely. But for a DD no problem.
76-914 |
Jul 30 2015, 08:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Mikey914 |
Jul 30 2015, 08:14 AM
I'd be suspect of that door lock bushing. Looks like a straight piece of tube. I know these should have a step in them. Do tell! Is that the plastic sleeve you sell? If so, would changing that sleeve make it OK? PS< received my order in full, Thx Mark. I actually machined an aluminum bushing as with grease over time the plastic breaks down. What I was concerned about was the piece I can see in the picture just looks like a straight tube. It may fill the bap, but I'm curious as if it has more play in it than it should. I do make the door cams also, but this appears adequate. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:42 PM |
