Calling L-Jetronic experts, component location in engine bay |
RohJay |
Jul 31 2015, 06:24 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
I purchased my car already converted to Dual Weber IDF 40's.
I am interested in reverting to Fuel Injection. It is a '75 1.8 ( Code EC), which I believe requires the L-Jetronic system. I will post a Want Ad on the classifieds for a COMPLETE, FUNCTIONAL assembly. Failing which, I anticipate having to source individual parts; the composition of which I am at a loss. I have found this Lapuwali blog entry listing all parts pertaining to D-Jet retrofit. I would very much appreciate a similar parts list for the L-Jet system. Thanks in advance Rohantha |
jim_hoyland |
Jul 31 2015, 06:27 AM
Get that VIN ? Group: Members Posts: 9,291 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I purchased my car already converted to Dual Weber IDF 40's. I am interested in reverting to Fuel Injection. It is a '75 1.8 ( Code EC), which I believe requires the L-Jetronic system. I will post a Want Ad on the classifieds for a COMPLETE, FUNCTIONAL assembly. Failing which, I anticipate having to source individual parts; the composition of which I am at a loss. I have found this Lapuwali blog entry listing all parts pertaining to D-Jet retrofit. I would very much appreciate a similar parts list for the L-Jet system. Thanks in advance Rohantha The good news is that newly all the parts are going to be available from people on the board. |
Mark Henry |
Jul 31 2015, 07:53 AM
I have every single part except the fuel pump off of my running 1.8 1974
I put the info over on your ad in the for sale section as it's a more appropriate place. |
RohJay |
Aug 6 2015, 08:44 AM
I've manged to purchase a '75 1.8 L-Jet FI system.... with some missing components.
Now I need to figure out what is missing. Please look over the parts below and indicate else is needed. Thanks in advance Attached thumbnail(s) |
Mikey914 |
Aug 6 2015, 08:56 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've manged to purchase a '75 1.8 L-Jet FI system.... with some missing components. Now I need to figure out what is missing. Please look over the parts below and indicate else is needed. Thanks in advance Hoses? Looks like something is funky with the injector harness. May want to have Bowlsby do you up a new one. Not a lot of fun to chase problems that are from bad wires. |
rhodyguy |
Aug 6 2015, 09:07 AM
look closely at the large elbow that connects the air flow sensor to the throttle body before you install it. even a tiny crack or split will screw things up. remember to buy a appropriate fuel pump, new phenolic gaskets, might as well new injector seals, oil fill tower gasket…all the disposables. prob send the injectors out for refurbish. any vac leaks and you'll have a permanent low idle.
914fahrer |
Aug 6 2015, 10:58 AM
Member Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
I miss the resistor pack
Gruss Ralf |
Geezer914 |
Aug 6 2015, 11:24 AM
Geezer914 Group: Members Posts: 1,409 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
You can block off the decel valve. It is a waste of time. As some one said, check that large elbow for cracks. I had rough idle problems. The elbow looked good and everything else checked out. Then I found a small crack right on the edge of the top hose clamp, on the bottom of the elbow. Replaced the elbow and it runs smooth.
Valy |
Aug 6 2015, 08:48 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Fuel rails are missing.
Y splitter for vacuum hose. |
Aug 7 2015, 09:48 AM
I see both fuel rails, and all four injectors.
The resistor pack is not evident, as 914fahrer said. Fuel hoses and vacuum lines should be replaced regardless, as they are almost certainly old and brittle and either cracked now or about to start. I don't see the "manifold boots", the ~2.5" wide ~3" long vacuum hoses that go from the plenum ("intake air distributor") to the intake runner pipes. Then again, those should be replaced anyway. Look for a CHT sensor in your right-side cylinder head near the #3 spark plug. If it's not there, you'll need to pick one up and install it. I don't see a fuel pressure regulator. I don't see a fuel pump. But pretty much any pump that can supply the specified pressure and volume should work. Note that the above items may still be present; I'm just not seeing them at this time. (Took me a couple of looks through to see the second fuel rail and injectors, for instance.) --DD |
RohJay |
Aug 8 2015, 08:21 AM
My appreciation to all those who commented.
Especially to DD... that was THOROUGH and exactly what I was hoping for. :-) I have so far purchased the Resistor Pack, Manifold Boots and Fuel Pump. The CHT and Fuel Press Reg are new to me. Will source those from from Pelican. Thanks again !!! |
RohJay |
Oct 30 2015, 07:47 AM
L-Jet system has eventually reached me in Sri Lanka and today we finally test fitted system... and it runs!
Getting it to run smoothly will happen soon enough I hope. I am trying to figure out where the in the engine compartment, the following components should be placed: 1. Thermo Time Switch (TTS) 2. Auxiliary Air Valve (AAV) 3. Injector Resistor Pack 4. Deceleration Valve Appreciate very much if anyone can identify the respective locations... pictures would be even better. Thanks |
914fahrer |
Oct 30 2015, 12:03 PM
Hello
I hope this help`s you Gruss Ralf |
Mueller |
Oct 30 2015, 12:14 PM
To help trouble shoot my old Ljet system I made plugs that go into the elbow to eliminate those hoses.
I want to say that even a bad oil filler cap oring can be problematic. |
RohJay |
Oct 30 2015, 01:08 PM
RohJay |
Oct 30 2015, 01:15 PM
To help trouble shoot my old Ljet system I made plugs that go into the elbow to eliminate those hoses. I want to say that even a bad oil filler cap oring can be problematic. Thanks, that's an excellent idea. I have already got back up o ring and oil filler housing gasket. |
914Mike |
Oct 30 2015, 10:46 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Resistor pack and double relay both mount on the battery tray support, IIRC. Under the battery for sure...
orthobiz |
Oct 31 2015, 06:31 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Another view of the AAV before I replaced some hoses...right behind the oil dipstick.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.staticflickr.com-7438-1446337874.1.jpg) Paul |
RohJay |
Nov 1 2015, 01:26 AM
Thanks 914Mike and orthobiz.
For the benefit of others who may have the same query: here is a picture of the Double Relay (yellow arrow) and Resistor Pack ( mounted directly below). Photo grabbed from a past ClayPerrine post... |
JeffBowlsby |
Nov 1 2015, 07:27 AM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
And here is a factory photo of the same condition:
Lo-Fi Version | Time is now: 14th May 2024 - 11:30 PM |
