Differential output shaft seal replacement procedure? |
Han Solo |
Jul 31 2015, 10:06 AM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
Looks like the hot weather and fast driving has made a slight leak into one that's creating a bit of a puddle. I found a thread on Rennelist for 924/944...
http://rennlist.com/forums/924-931-944-951...-procedure.html ...but is there one here for 914? Same procedure? Any tips? Thanks gents! |
Dr Evil |
Jul 31 2015, 01:46 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Tq on bolt is 19 ft/lb. Seal does not bottom out on its own. It will stop when it hits the diff bearing itself, but that is too far. You will only need to push it in until flush with the little step that you can feel that starts at the seal bore. As long as you don't warp it putting it in, yer cool. I lube the seal outer to aid in seating. I also slowly take a large dia something (I have a metal slug) and slowly tapp around the perimeter to seat it. Slow is good because if you gobo far you may ruin it pulling it back out. When am doing them the case is empty and I can push through and try again. Always better to instal and remove to try again in same direction.
Lo-Fi Version | Time is now: 27th May 2024 - 06:38 PM |
