Injector tip seal mystery |
Amphicar770 |
Aug 1 2015, 01:37 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hi all,
Noticed some fuel leaking at the injector today. Have new ones and new seals so figured a good time to put them in. Upon removing the two old injectors, I can only find the tip seal on one of them. Is it possible that it disintegrated and got sucked into the engine. Either that or I need to look harder?? Thanks. Mike |
914Mels |
Aug 1 2015, 02:24 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
they are usually either stuck on the injector or stuck in the manifold, maybe it dropped off and "hid" when you pulled the injector but I doubt it ended up in the engine.
Amphicar770 |
Aug 1 2015, 05:20 PM
Thanks. Yes, I found the little bugger hiding on one of the engine tins. All fixed now.
Lo-Fi Version | Time is now: 21st May 2024 - 04:49 AM |
