Amphicar770
Aug 1 2015, 01:37 PM
Hi all,
Noticed some fuel leaking at the injector today. Have new ones and new seals so figured a good time to put them in.
Upon removing the two old injectors, I can only find the tip seal on one of them. Is it possible that it disintegrated and got sucked into the engine. Either that or I need to look harder??
Thanks.
Mike
914Mels
Aug 1 2015, 02:24 PM
they are usually either stuck on the injector or stuck in the manifold, maybe it dropped off and "hid" when you pulled the injector but I doubt it ended up in the engine.
Amphicar770
Aug 1 2015, 05:20 PM
Thanks. Yes, I found the little bugger hiding on one of the engine tins. All fixed now.
