Thanks Rusty! Got my new muffler!, Question on coating/painting it |
SteveL |
Feb 28 2005, 09:26 AM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
The UPS truck just left after dropping off my new-to-me muffler for my 1.8. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Rusty described it as excellent condition, and it is at least that, if not better. It still has some of the factory primer on it even, and absolutely no rust - not even surface rust. I want to coat it to keep it that way. I've tried hi-temp bar-b-queue paint before, with less than stellar results. What have others used that works well?
TIA Steve |
scotty914 |
Feb 28 2005, 09:28 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
por 15 manifold paint
Cap'n Krusty |
Feb 28 2005, 10:03 AM
Cold Galvanizing paint, available at welding supply stores. Even the "correct" color. The Cap'n
Rusty |
Feb 28 2005, 10:13 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Glad it worked for ya! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
-Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
Eric_Shea |
Feb 28 2005, 10:21 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Which is called POR-20. I did both systems with it. New 914 headers got blasted and then repainted with POR-20. Sport muffler as well. 911 heat exchangers and stock muffler got the treatment as well. Should be good to 1400 deg. Others here (Jim) said it still looks as good as the day it was applied. |
StratPlayer |
Feb 28 2005, 11:22 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Go with Por20 or Bill Hirsh high temp paint good for 2K degrees.
http://www.hirschauto.com/acb/showdetl.cfm...ct_ID=11&DID=27 |
Type 4 |
Feb 28 2005, 11:26 AM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Bill Hirsh 1800 Hi temp get the pint can rather than the spray can.
It works really well. |
bperry |
Feb 28 2005, 12:01 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
So are you guys spraying it on or using brushes?
--- bill |
StratPlayer |
Feb 28 2005, 12:27 PM
I just refurbished a set of 75-76 exchangers, I used Bill Hirsh high temp paint on the exhangers and plumming, I used the spray can paint that he sells. On my car I painted the muffler with por20 high temp paint and I brushed this paint on the muffler. It shows no brush marks when this paint drys.
Eric_Shea |
Feb 28 2005, 01:38 PM
For mine (POR20) we sprayed... headers heat exchangers, all a big spaghetti mess. For a muffler I'd just brush it on.
Type 4 |
Feb 28 2005, 03:56 PM
I use a foam Brush.
SteveL |
Mar 1 2005, 10:52 AM
I picked up some of the POR 20 - the only color they had is "Brilliant Aluminum". Is that the only color it comes in? I did a test piece and it's pretty bright silver. I think it would looke kinda ricey. Are other colors available? What about the POR Manifold paint - the can says it replicated the gray color of factory cast parts.
Triaddave |
Mar 1 2005, 10:59 AM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
VHT make a high temp paint in a spray can.(VHT, very high temp 1500 degree) seen in excellence or performance catologs, allow at least two cans. the local auto stores only usually stock the 1200 stuff,junk
Lo-Fi Version | Time is now: 17th May 2024 - 05:52 PM |
