will this muffler fit and what sound should i expect, for sale local to me |
thelogo |
Aug 2 2015, 04:42 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Exhausts looks nice
Will it fit my 1.7 With notched rear balance And what kinda sound should I expect http://losangeles.craigslist.org/lac/pts/5150524940.html (IMG:style_emoticons/default/beerchug.gif) |
thelogo |
Aug 2 2015, 04:48 PM
I talked to seller
But wanted to check here also """Hi I'd like to get the exhaust system But what would you say the noise level or difference will be from stock ,slightly louder , much louder , or obnoxious loud . Me ? Seller Hi. It will probably be a little louder than stock undrr acceleration. Sportier. It's a brand new turbo muffler never installed. I decided to go with a header. Thanks Gary Hi Gary and will it fit a 1.7 engine with the notch exit location ? Me It should it was o n my 1.7. But every car is different .Muffler is a little bigger so you may need to dent it a little to fit. My suggestion would be to have a muffler guy change it out and they should he able to fit it easily. Seller |
JawjaPorsche |
Aug 2 2015, 04:51 PM
Here is chart to help you make sure it will fit your exchangers.
thelogo |
Aug 2 2015, 05:02 PM
JawjaPorsche |
Aug 2 2015, 05:06 PM
Yes, take tape measure. Inside holes should be 21.5 apart. Measure center of the hole to center of the hole. (CAN NOT BE LESS! If it is, it is probably a 2.0)
Outside holes should be 29.5. If not, it is probably for a 2.0 The 1.7 body models also had a different hole for the roll pan. Maybe someone else can offer more information. What year is your 914? Hope this helps. |
thelogo |
Aug 2 2015, 05:15 PM
http://m.summitracing.com/parts/wlk-17704?...EFo0BoC_VDw_wcB
So it's a 30 dollar muffler welded to a 914 manifold What do you think this cost to make yourself? |
7TPorsh |
Aug 2 2015, 05:32 PM
It will fit the early exchangers with the turned up pipes in back. Excgangers are listed in cg too. I'm the seller. Any issue may be the muffler will need a dent or too to fit depending on the car which is normal. You can have all this made but it won't be for $125.
thelogo |
Aug 2 2015, 05:47 PM
It will fit the early exchangers with the turned up pipes in back. Excgangers are listed in cg too. I'm the seller. Any issue may be the muffler will need a dent or too to fit depending on the car which is normal. You can have all this made but it won't be for $125. Ok fair enough I think I'll pass , on any other car I would try to fit it in But the 914 , I don't like taking it to a " muffler guy " For experimental fitting . I don't like taking it to any shops ,except 1 guy . Steve s machine shop in azuza Prefer to install myself , But thanks for being straight with me . |
Valy |
Aug 2 2015, 06:24 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Regarding the sound, its something like brrruuuuummmmm!
Chris H. |
Aug 2 2015, 07:06 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
thelogo |
Aug 2 2015, 07:44 PM
Great I was thinking more like Vroooooooom (IMG:style_emoticons/default/driving-girl.gif) But that s why you all are the experts here (IMG:style_emoticons/default/beer3.gif) |
rhodyguy |
Aug 3 2015, 07:12 AM
exhaust note will be comparable to a bursch. shipping $ will prob suck.
maf914 |
Aug 4 2015, 06:06 AM
If the exhaust system is local to you as your post states, why not drive your car to the seller, unbolt your current system, six bolts, and test fit the new system? With new bolts removal of the muffler is one of the easier 914 tasks. Wear gloves as that system will be hot! (IMG:style_emoticons/default/idea.gif)
SLITS |
Aug 4 2015, 06:36 AM
It's a flippin' Sebring exhaust system with a different muffler attached. The original was a round glass pack as I remember. It would burn out fairly rapidly with a commensurate increase in loudness in the exhaust note.
Bursch had the oval muffler like the one pictured. Performance Products sold them for one. At the time they were $129 new. I had one on my 1971 back in the day. |
EdwardBlume |
Aug 4 2015, 08:01 AM
7TPorsh |
Aug 4 2015, 09:02 AM
RRRRRAAAAAAAAAWWWWWWWW!!!!.....shift.....RRRRRAAAAAAAWWWWWW....shift....repeat
mrholland2 |
Aug 4 2015, 09:21 AM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
I think it would be clever if we could make them sound like original Beetle exhausts
(IMG:style_emoticons/default/screwy.gif) |
ripper911 |
Aug 5 2015, 08:44 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I think it would be clever if we could make them sound like original Beetle exhausts (IMG:style_emoticons/default/screwy.gif) I love that sound. (IMG:style_emoticons/default/wub.gif) |
aircooledtechguy |
Aug 5 2015, 12:15 PM
I think it would be clever if we could make them sound like original Beetle exhausts (IMG:style_emoticons/default/screwy.gif) I love that sound. (IMG:style_emoticons/default/wub.gif) That would be a "fweeeeeeeemmmmm"!! I have the same system on my car. It works fine. It was a bit restrictive on my 1.8L and made the engine sound like a Beetle/Bus engine since it had the exact same single quiet pack muffler (poorly designed muffler). So I removed the stock muffler it came with and built my own dual dump similar to a Triad. It worked great but was a bit too loud on early mornings. So I built my own single muffler that is similar in design, on the inside, to a Flowmaster 40 and had my son Josh weld it up for me (his first welding project). It sounds good now and runs very well with it. I had to make my own because a Flowmaster is too large for the area it needs to fit in. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:15 PM |
