Wierd fog light issue.. |
falcor75 |
Aug 3 2015, 06:12 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I have got a wierd issue with my foglights. I followed this: http://members.rennlist.com/demick/fogrewire.html procedure to get my foglights to act as DRL's with the ignition on. (option 1b)
With ignition on and the fog light switch pulled out the switch lights up and I get 12v on the wires to the foglights, so far all is well. But as soon as I connect a bulb to either of the wires the voltage drops to 0 volts. (IMG:style_emoticons/default/blink.gif) I'm kinda stumped to what's going on.... |
Spoke |
Aug 3 2015, 11:46 AM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Which one of the conversions did you do? Does the light on the switch stay on?
Best thing to do now is recheck all your wiring. If it all checks out, follow the wires back from the light fixture to the relays and on to the fuse panel. Somewhere the voltage stops. You need to find that somewhere. |
Larmo63 |
Aug 3 2015, 12:32 PM
The JWest wiring harness that is available on eBay is a good solution to the weird stock fog light arrangement on a 914. It makes the fog light switch operate totally independent of the headlight switch. I like that option because I can also flash my fogs with the high beam switch.
Much better. |
falcor75 |
Aug 3 2015, 12:46 PM
I've never been so happy about a broken relay... (IMG:style_emoticons/default/beerchug.gif)
Edit: Just because a relay clicks it doesnt mean its ok....had the same issue with the headlight relay....I should have learned.... (IMG:style_emoticons/default/headbang.gif) |
rhodyguy |
Aug 3 2015, 05:22 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Nice! Hassle averted.
Porschef |
Aug 3 2015, 06:14 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
The JWest wiring harness that is available on eBay is a good solution to the weird stock fog light arrangement on a 914. It makes the fog light switch operate totally independent of the headlight switch. I like that option because I can also flash my fogs with the high beam switch. Much better. (IMG:style_emoticons/default/agree.gif) It's so simple to install, your fogs become intuitively usable as flashers, and should you use them at night along with the headlights, they won't go out when the brights are on, unless you turn off the switch. A very nice upgrade. |
Lo-Fi Version | Time is now: 21st May 2024 - 05:15 AM |
