Taillight seals |
Taillight seals |
BCinSC |
Jun 8 2003, 04:18 PM
Nothing but Trouble Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
Where can I get them? (IMG:style_emoticons/default/unsure.gif) Thanks,
Aaron Cox |
Jun 8 2003, 04:24 PM
Lawrence |
Jun 8 2003, 04:25 PM
Hi BC and welcom to the 914 Club.
I don't know of a source. Here's a tip passed on to me. Get some RTV and vaseline. Put vaseline on the car body at the seal mating survaces. Use sparingly. Then, use a small amount of black RTV and then press them gently to the body. After the RTV cures, then tighten down the nuts. That should help create a seal, and the vaseline will prevent the RTV from sticking to your paint. You should be able to reuse them. Let us know if you find a source for the seals! -Rusty |
BCinSC |
Jun 8 2003, 04:28 PM
Hi Rusty. Seen you plenty on RennList. Anyway, forgive my naivete, but RTV? (IMG:style_emoticons/default/wacko.gif)
Lawrence |
Jun 8 2003, 04:34 PM
Yeah, I know that "there's no place on a 914 for RTV." But seriously, it helps create a nice new water-tight surface. Someone on Rennlist gave me that tip.
-Rusty |
Aaron Cox |
RTV = room temperature vulcanizing (rubberizes) at room temp. silicone
anthony |
Jun 8 2003, 05:08 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Beware, I did the vaseline thing and the tail light housings still got glued to the car. Actually one was already glued so now they match. :-) And they still leak, just a whole lot less. If I did it again I think I'd do the following:
Put lots of vaseline on the body Put a bead of RTV on the tail light housing Let bead partly dry so that the surface is no longer tacky (at this point I might even talc the bead of RTV) Press the housing against the body (I made the mistake of tightening the nuts). |
djm914-6 |
Jun 8 2003, 05:27 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
I have the AA seals (didn't know better when I bought them). It looks like simple neroprine (SP???) rope. I remember reading... some where... that this stuff is available at places like Home Depot.
Hey Bruce, do rednecks like you know of Home Depot, or do you still just let the porch fall and see how many dogs bite it? (IMG:style_emoticons/default/biggrin.gif) |
djm914-6 |
Jun 8 2003, 05:32 PM
Lo-Fi Version | Time is now: 20th May 2024 - 12:07 AM |
