BCinSC
Jun 8 2003, 04:18 PM
Where can I get them?
Thanks,
Aaron Cox
Jun 8 2003, 04:24 PM
AA has them....sometimes on ebay
(ducking)
Lawrence
Jun 8 2003, 04:25 PM
Hi BC and welcom to the 914 Club.
I don't know of a source.
Here's a tip passed on to me. Get some RTV and vaseline. Put vaseline on the car body at the seal mating survaces. Use sparingly. Then, use a small amount of black RTV and then press them gently to the body. After the RTV cures, then tighten down the nuts. That should help create a seal, and the vaseline will prevent the RTV from sticking to your paint. You should be able to reuse them.
Let us know if you find a source for the seals!
-Rusty
BCinSC
Jun 8 2003, 04:28 PM
Hi Rusty. Seen you plenty on RennList. Anyway, forgive my naivete, but RTV?
Lawrence
Jun 8 2003, 04:34 PM
Yeah, I know that "there's no place on a 914 for RTV." But seriously, it helps create a nice new water-tight surface. Someone on Rennlist gave me that tip.
-Rusty
Aaron Cox
RTV = room temperature vulcanizing (rubberizes) at room temp. silicone
anthony
Jun 8 2003, 05:08 PM
Beware, I did the vaseline thing and the tail light housings still got glued to the car. Actually one was already glued so now they match. :-) And they still leak, just a whole lot less. If I did it again I think I'd do the following:
Put lots of vaseline on the body
Put a bead of RTV on the tail light housing
Let bead partly dry so that the surface is no longer tacky
(at this point I might even talc the bead of RTV)
Press the housing against the body (I made the mistake of tightening the nuts).
djm914-6
Jun 8 2003, 05:27 PM
I have the AA seals (didn't know better when I bought them). It looks like simple neroprine (SP???) rope. I remember reading... some where... that this stuff is available at places like Home Depot.
Hey Bruce, do rednecks like you know of Home Depot, or do you still just let the porch fall and see how many dogs bite it?
djm914-6
Jun 8 2003, 05:32 PM
