Tachometer Anomaly, Pegged at 7K |
Ansbacher |
Aug 5 2015, 06:19 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Upon turning key on in the Harbor Freight parking lot today, my tach immediately pegged at 7K. Tried key a few more times, same thing. Figured I'd troubleshoot at home, so actually started car to go. Tach jumped around for a second and then settled into normal operation. Has not done it since. Any ideas as to the gremlin that would cause this? First time tach has ever acted up.
Ansbacher |
stugray |
Aug 5 2015, 07:46 PM
Probably not related, but MSD 6AL ignitions that have the rev limiter enabled will peg the tach to the value that the rev limiter is set to when you turn on the ignition for about 3 seconds.
It would behave exactly like that if the rev limit was set to 7k. But I'm guessing you would know that if you had a MSD. |
Ansbacher |
Aug 5 2015, 08:17 PM
I am running conventional points type ignition with a centrifugal advance dizzy.
914Sixer |
Aug 5 2015, 08:50 PM
Check the engine harness from the relay board . The wire is black with purple stripe.
ConeDodger |
Aug 5 2015, 09:02 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Ground. (IMG:style_emoticons/default/chair.gif)
porschetub |
Aug 5 2015, 09:06 PM
x2 exactly the issue,it can be a big old mess behind the gauge holder,best to check in there first,cheers.
Lo-Fi Version | Time is now: 15th May 2024 - 12:34 PM |
