PMB Performance - Pressure Regulator Restoration Service, The only full restoration service on the planet! |
Eric_Shea |
Aug 6 2015, 11:49 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Repeat after me, "Pressure Regulator" -- "Pressure Regulator"
That's right, this little beast is a pressure regulator, "NOT" a proportioning valve. It proportions "NADA". It is the first anti-lock brake device ever to be installed on a Porsche. Here's the story: The 914 is a mid-engine automobile. As such, it has amazing handling characteristics... to a point. Once that point is reached, it can bite you like a rabid dog. It's a physics principle called "Polar Moment Inertia". We're all familiar with the childs play toy the "top". Here it is straight out of Mr. Elford's mouth: http://www.amazon.com/Porsche-High-Perform...d/dp/0760327548 Porsche knew the issues with rear and mid-engined automobiles so, they installed this pressure regulator in the system to prevent the rear wheels from ever locking up. You see, if you lock your rear wheels in a rear or mid-engine car and your front wheels are anything but straight, you can be that "top" we were talking about and, that's not a fun toy at that time. This pressure regulator senses a panic stop (which it is set and locked at 525psi). Once it sees that pressure on the system, the valve body slides over and activates a So, yeah, the internet guru's steered you in the wrong direction. You "never" want to replace this regulator with a "T" fitting in a street car and, you want to make sure it's operating properly otherwise, your rear calipers aren't even working and, that's 30% of your braking power. Here's what we do; We will completely disassemble the regulator. We will zinc plate the spring housing and the valve housing. We will clean and reseal the valve body using new EPDM seals throughout. We will repaint the freshly plated spring housing and the valve housing. We will zinc plate the mount and the fasteners. We will then reassemble the regulator and reset the pressure switch to 525psi. We will then epoxy the lock nut just like the factory and send you back a perfectly operating pressure regulator that not only makes sure you and your passengers are safe but, it give you back your full braking potential so your 914 stops as good as it did when it was new (and that's still damn good my friends). $169.95 plus $15.00 shipping in the Continental United States (we ship worldwide) Early Cars (you'll have a brass "T" fitting at the top): http://www.pmbperformance.com/914-brakes/E..._Regulator.html Late Cars (you'll have a different right line that exits the valve in the rear): http://www.pmbperformance.com/914-brakes/L..._Regulator.html Spot on factory two-tone finish: |
Aug 6 2015, 11:59 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Cool. Do we send you cores?
Eric_Shea |
Aug 6 2015, 12:24 PM
Yes Sir. This is a rebuild of your cores.
aharder |
Aug 6 2015, 01:59 PM
Advanced Member Group: Members Posts: 4,379 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
How long will it take you to rebuild?
Aug 6 2015, 03:05 PM
wes |
Aug 6 2015, 04:40 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I have a 73 parts car and a 74 that is hopefully finished this next week for her first trip out of the stall and off to Monterey, so is the 73 the same as 74?
Eric_Shea |
Aug 6 2015, 11:45 PM
It depends Wes. 1974 is when they made a change in the pressure regulator. Late model 1974 have a late model pressure regulator.
LowBridge |
Sep 1 2015, 12:03 PM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
I would like to give PMB a plug for fantastic customer service. I order calipers for all 4 corners and everything arrived on time and looking so good it's almost a crime to bolt them onto the car.. almost (IMG:style_emoticons/default/tongue.gif) .
Additionally I messed up on my end by ordering a few items incorrectly and they had no issues helping get me the correct parts. and on top of all of this I was one of those customers who has a "Deadline" (IMG:style_emoticons/default/biggrin.gif) and they just made it happen. great job PMB and thank you... |
LowBridge |
double post.. (IMG:style_emoticons/default/blink.gif)
JmuRiz |
Sep 2 2015, 02:20 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Question:
I have boxster calipers on the front of my car, stock on the rear...and replaced the regulator with a T...would you suggest a modified regulator or stick with the T in this scenario. FWIW: When I went to a HPDC way back when the pass-side rear would lock (only that side) so I'm guessing it's a vent clearance thing and not a T thing. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:44 PM |
