Interior Door Handles, Location of best repair procedure |
earossi |
Aug 7 2015, 08:07 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
One of my interior door handles no longer operates the door latching mechanism. I can open the door using the exterior latch. Can someone point me in the right direction for a DIY article on how to fix the non-functioning interior handle?
914Sixer |
Aug 7 2015, 08:33 PM
914 Guru Group: Members Posts: 8,873 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Remove the door latch assembly from inside the door. Soak and clean 40 yrs of white grease off of it. Lube and reinstall.
earossi |
Aug 7 2015, 09:09 PM
Remove the door latch assembly from inside the door. Soak and clean 40 yrs of white grease off of it. Lube and reinstall. Thanks for your response. But, isn't there a pull rod that connects the interior door actuator with the door latch? I can pull the interior door lever just fine; however, that does not translate into any action at the door latch. |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:49 PM |
