Centre "deposit '' box, another option besides the centre console. |
porschetub |
Aug 15 2015, 05:26 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have info and measurements from Jeffs website for the centre console,I would prefer to have the so called "deposit box''.
Anyone have a similar measurement plan or do I just build the main section off Jeffs plan and go from there?. I want it to look/fit as close to original as possible,thanks. |
914_teener |
Sep 11 2015, 11:36 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
...Or were you talking about the plastic center section underneath the center cushion.
Pat Garvey |
Sep 11 2015, 06:05 PM
...Or were you talking about the plastic center section underneath the center cushion. The "deposit box", as Porsche marketing called it, was/is a compartment from the lower center of the dashboard on early 914's to the floor. It was affixed top and bottom with stainless hardware, carpeted on the sides, a vinyl floor and that was it. Was meant to hold the deitris of your commute. Some places who should know better (Auto Atlanta) will attempt to make you believe that it was the center console on later year 914s. They are (typically) incorrect. There's a huge difference between a "deposit box" and a "console". Don't be fooled by the fools! Pat |
914_teener |
Sep 11 2015, 06:48 PM
...Or were you talking about the plastic center section underneath the center cushion. The "deposit box", as Porsche marketing called it, was/is a compartment from the lower center of the dashboard on early 914's to the floor. It was affixed top and bottom with stainless hardware, carpeted on the sides, a vinyl floor and that was it. Was meant to hold the deitris of your commute. Some places who should know better (Auto Atlanta) will attempt to make you believe that it was the center console on later year 914s. They are (typically) incorrect. There's a huge difference between a "deposit box" and a "console". Don't be fooled by the fools! Pat Thanks for the clarification Pat. Mine is a 73 with the interior like your car. Deposit box and a center console. The pad comes out and underneath is the "plastic" center which the center console pad sits. Good to see you posting again. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:55 AM |
