BUILD-OFF CHALLENGE: Eisberg rustoration, Need some input... |
mbseto |
Aug 16 2015, 07:32 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Funny, I am as nervous starting this thread as I was to start cutting into my car.
I resolved to start a rustoration thread when I made my first cuts, so here it is. I'm hoping the community will pipe in periodically with any, "Don't do that!", "Do it this other way!", "Do this first!", or "Don't forget this!" comments that are appropriate. Any and all guidance will be appreciated. So here's the car as I got it, not quite a year ago: Started out doing a little engine work to get it running, then drove it around a little bit before starting to take it apart. Took the engine out, put it up on a dolly, took out much of the interior and suspension, and this is how it sits now: After cleaning out the inside and seeing the rust, it was hard to believe we were driving it at all. These are the first cuts, just straightening out the edges of the rust holes really. More pics coming soon, I'll be documenting the extent of the damage and forming a battle plan. |
mbseto |
Aug 17 2015, 06:44 PM
Shouldn't the door braces form an "X" or a "Z"? Not saying that the car is going to move since it's bolted to that beefy support frame, but I don't see how a "four-bar brace" keeps the jambs fixed relative to each other (think sagging fence gate without the diagonal brace). I intended the dolly and the braces to all work together- they will all remain attached so far as possible. Both braces on each side are adjustable to set door gaps. The plan is to measure frequently and if anything sags during the cutting, I will add bracing before welding. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:52 AM |
