BUILD-OFF CHALLENGE: Eisberg rustoration, Need some input... |
mbseto |
Aug 16 2015, 07:32 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Funny, I am as nervous starting this thread as I was to start cutting into my car.
I resolved to start a rustoration thread when I made my first cuts, so here it is. I'm hoping the community will pipe in periodically with any, "Don't do that!", "Do it this other way!", "Do this first!", or "Don't forget this!" comments that are appropriate. Any and all guidance will be appreciated. So here's the car as I got it, not quite a year ago: Started out doing a little engine work to get it running, then drove it around a little bit before starting to take it apart. Took the engine out, put it up on a dolly, took out much of the interior and suspension, and this is how it sits now: After cleaning out the inside and seeing the rust, it was hard to believe we were driving it at all. These are the first cuts, just straightening out the edges of the rust holes really. More pics coming soon, I'll be documenting the extent of the damage and forming a battle plan. |
mbseto |
Oct 6 2015, 09:51 PM
ha; timely update. I was just ruminating over how to make my own sheetmetal brake. Can you show a pic of how it works? Took these after dark, hope they show it well enough. The brake is just three pieces of angle iron. Two are hinged together and bolted to the stand, the third is used as a clamp. This is what it looks like set up with a small test strip: Once the sheet is clamped in place, you just lift up on the handles like so: Of course it's going to spring back some. You can find tables that tell you how far to bend it so that it springs back to the angle you want. You can also muscle it after the fact. Here's a close shot of the hinge. It's very simple. And the best part is, it folds up! |
Lo-Fi Version | Time is now: 15th May 2024 - 12:55 PM |
