BUILD-OFF CHALLENGE: Eisberg rustoration, Need some input... |
mbseto |
Aug 16 2015, 07:32 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Funny, I am as nervous starting this thread as I was to start cutting into my car.
I resolved to start a rustoration thread when I made my first cuts, so here it is. I'm hoping the community will pipe in periodically with any, "Don't do that!", "Do it this other way!", "Do this first!", or "Don't forget this!" comments that are appropriate. Any and all guidance will be appreciated. So here's the car as I got it, not quite a year ago: Started out doing a little engine work to get it running, then drove it around a little bit before starting to take it apart. Took the engine out, put it up on a dolly, took out much of the interior and suspension, and this is how it sits now: After cleaning out the inside and seeing the rust, it was hard to believe we were driving it at all. These are the first cuts, just straightening out the edges of the rust holes really. More pics coming soon, I'll be documenting the extent of the damage and forming a battle plan. |
mbseto |
Aug 21 2016, 10:23 AM
Now the car is mounted on 4 points again and I can adjust to get those points level. But the two halves are tilted away from each other. I can adjust the door braces to fix that, but I need to know how much.
I made a couple little metal tabs with a hole, and clamped them to the corners of the wheel wells, front and back. Now I can see if the bottom edges of the quarter panels line up or not... Then I can crank on the door braces to tilt the halves until they line up... Looks better: Now I'm sure someone is thinking, what about door gaps? I haven't forgotten... The door braces have to be adjusted in tandem to get the gaps right and also the alignment. That said, getting this right is probably the thing I am most worried about. And a little postscript... Took a hint from Jeff Hail's thread and got myself one of these little monkeys. I've seen them for as much as $30 at industrial and car places... Home Dep has them for $8 and change. - |
jmitro |
Aug 29 2016, 11:10 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Very nice work. i'm impressed with your forethought and creativity.
Reading this is making me think I need to redo my longitudinal restoration. |
Lo-Fi Version | Time is now: 22nd May 2024 - 09:46 AM |
