6 cylinder oil scavenge line, With heat exchangers |
'73-914kid |
Aug 18 2015, 04:09 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Quick question for those of you running heat exchangers and an external oil cooler..
What did you do for the oil scavenge line that come out of the passenger side of the engine case? I have an old pipe that someone welded a -12 AN fitting to, however it was pinched long before I ever came across the engine, and I'm looking for an alternative. Patrick motorsports sells a line than looks exactly like mine for $160 (option 1) My other thought was to run an AN line off the case to my thermostat at the firewall, however I don't know if there is sufficient room for this line to fit with heat exchangers and the heater boxes. So, what have some of you done that are in this situation? I would much rather build a line myself with AN fittings than blow a bunch of cash on a rather simple oil pipe from PMS.. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:15 PM |
