How hot is the oil at this mark on the gauge? |
pete000 |
Aug 20 2015, 11:38 AM
How hot is the engine oil at this point on the gauge? Stock temp sender and mounting.
Attached thumbnail(s) |
MJHanna |
Aug 20 2015, 11:43 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
Half way between cold and really hot. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/av-943.gif)
whitetwinturbo |
Aug 20 2015, 01:11 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Half way between cold and really hot. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/av-943.gif) ...........touch the glass (IMG:style_emoticons/default/lol-2.gif) ? |
screenguy914 |
Aug 20 2015, 01:43 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
How hot is the engine oil at this point on the gauge? Stock temp sender and mounting. I guess the 914 help desk has spoken. (IMG:style_emoticons/default/rolleyes.gif) Not familiar with that gauge, but if similar to 911 VDO oil temp gauges, you might look at the vertical side of the gauge at an oblique angle and see numbers that relate to the actual temperature. But 914 gauges apparently aren't that revealing. Here's a related thread from Pelican Parts forum that might provide more info. http://forums.pelicanparts.com/porsche-914...temp-gauge.html Sherwood |
Steve Snyder |
Aug 20 2015, 02:46 PM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
Straight up is 100 degrees Celsius.
Range begins at 30 degrees. Redline begins at 156.7 degrees and ends at 170 degrees. It's actually marked, but you must disassemble the gauge (including prying off the bezel) to be able to see it. (IMG:style_emoticons/default/WTF.gif) |
914Sixer |
Aug 20 2015, 04:59 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just take the 4 screws of the back of the gauge and pull it out. You can see scale. I included a shot of the 911 scale as a reference. My stock 914 temp has been modified to accept a light bulb by using the base of a gas gauge like the factory 911 one has but on the other side.
Steve Snyder |
Aug 20 2015, 05:26 PM
...yeah, was thinking of disassembly of the console temp gauge. Getting old has its drawbacks...
pete000 |
Aug 20 2015, 05:37 PM
Thanks for the info!
Firstcar |
Aug 20 2015, 07:19 PM
Obsessive amateur mechanic Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
Answer to OP's Q: About 212 degrees - optimum operating temperature
turk22 |
Aug 20 2015, 08:07 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
flipb |
Aug 21 2015, 12:49 PM
Senior Member Group: Members Posts: 1,721 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
turk22 |
Sep 18 2015, 07:27 PM
Flip,
check out this site: http://www.p914.com/ go to the gauges section, and it should answer your questions. Turk |
Sep 18 2015, 07:31 PM
...yeah, was thinking of disassembly of the console temp gauge. Getting old has its drawbacks... Attached image(s) |
Mark Henry |
Sep 19 2015, 01:23 PM
I wouldn't trust any of this info especially with VDO and who knows if it's even the correct sender.
I'd bench test it with the sender in boiling water, then at least you know exactly where 100C is. |
Lo-Fi Version | Time is now: 9th May 2024 - 06:45 AM |
