Coldwater 914 Subaru conversion kit $1500 |
John1180 |
Aug 20 2015, 02:59 PM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
Bought this from Ian a while back, never used! Engine cradle and mounts, transaxle conversion kit, axle shafts, and cable shift conversion. Located in Seattle $1500
jmschneeman@msn.com Attached thumbnail(s) |
mepstein |
Aug 20 2015, 03:42 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I don't need the engine or transaxle mounts but I'll buy the rest if it gets split up.
jimkelly |
Aug 20 2015, 08:16 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
how much for what mark does not want?
John1180 |
Aug 20 2015, 10:11 PM
You guys get together and figure out how you want to split up the $$. If it adds up, I'm happy to do it that way
matthepcat |
Aug 21 2015, 12:42 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I need all this stuff too but the Bremar coupler and cradle.
Does the cable shift not come with the actual shifter assembly? |
John1180 |
Aug 21 2015, 11:43 AM
Does the cable shift not come with the actual shifter assembly? [/quote] The cable shift kit was made by Coldwater 914 to mate a Subaru trans to a Toyota MR2 shift assembly |
flmont |
Aug 21 2015, 09:17 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
How much for the cradel,but it needs to fit a flat 6 ???
mepstein |
Aug 21 2015, 09:24 PM
John - I sent you an email this morning. Thanks, mark
jimkelly |
Aug 22 2015, 06:53 AM
this mr2 shifter I think
John1180 |
Aug 26 2015, 10:03 AM
Bump, still available
mepstein |
Aug 26 2015, 02:32 PM
I PM'd you but never heard back
Chris H. |
Aug 26 2015, 03:57 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
The kit does not come with a shifter. MR2 like the one pictured is your best bet. e-bay or a pick n pull. They're cheap.
flmont |
Aug 26 2015, 05:13 PM
So whats up with the cradle,..is it available,..???
John1180 |
Aug 26 2015, 07:30 PM
flmont |
Aug 26 2015, 08:33 PM
Hi,.John I just need the cradle but its got to fit a flat 6 ...EG33..??
John1180 |
Aug 26 2015, 10:24 PM
madmax914 |
Aug 27 2015, 09:54 AM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
John, if you plan on parting this package out I will take the 2WD coupler and end plate. PM me and let me know. I would be interested in the cables and shift assembly for the right price.
Chris H. |
Aug 27 2015, 10:35 AM
I don't think it will work for a six, you could check with Ian at Coldwater. Hi,.John I just need the cradle but its got to fit a flat 6 ...EG33..?? It work will for for an EZ30, rnellums is using it. The EG33 poses a couple of challenges. It's really the only engine that does. I started off with that cradle. It positions the engine very close to the firewall (almost touching) which is due to the fact that it is universal, fitting almost any Subaru engine available. It also requires you to use the stock engine mounts which are very expensive and frequently need replacement on donor cars due to age. They are liquid filled and unique to the SVX. If you had a way to fabricate solid engine mounts to use in place of the stock ones you could use it. For the EG33 it would be better to fab one using an older engine mount bar like mine is. Luckily someone much more talented than me made mine, but take a look at amenson's thread and you will get an idea of what it takes. Sorry to take over the thread, but maybe it will save some questions coming your way. It's a VERY STRONG, well-made cradle BTW. Something else will certainly break before it does. |
John1180 |
Aug 29 2015, 06:00 PM
Dropped price to $1500 for the complete set up
dangerranger01 |
Aug 30 2015, 05:56 PM
Member Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
PM sent
Lo-Fi Version | Time is now: 5th May 2024 - 09:20 AM |
