| r_towle |
Dec 24 2024, 08:45 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
So technically a full rebuild
| sixnotfour |
Dec 25 2024, 12:22 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,183 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| porschetub |
Dec 25 2024, 01:00 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
So technically a full rebuild Today yes....BITD No,, top end time,, and while youre there..rod bearings.. (IMG:style_emoticons/default/agree.gif) ,the job is so much bigger than just doing guides ,one of those "while you are in there " jobs which IMO is critical with a 911 motor and that can't be ignored. Strange that ran one rod bearing ? the 3.2 is regarded as being strong in that area , old news but just asking ,cheers. |
| mepstein |
Dec 25 2024, 08:26 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,586 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
3.2’s have undersized rod bolts. If you use stock rods, you always upgrade the bolts to ARP.
We rarely do just a top end. We can’t “warranty” the rebuild without splitting the case. Who knows what else is wrong. Intermediate shaft bearing, main bearings, issues with the fuel pump, etc. Every time we open one up, there’s always something that makes us say that we are glad we split the case. It’s not cheap but it’s really expensive to have to go back in and do it twice. |
| sixnotfour |
Dec 26 2024, 08:45 AM
3.2’s have undersized rod bolts. If you use stock rods, you always upgrade the bolts to ARP. We rarely do just a top end. We can’t “warranty” the rebuild without splitting the case. Who knows what else is wrong. Intermediate shaft bearing, main bearings, issues with the fuel pump, etc. Every time we open one up, there’s always something that makes us say that we are glad we split the case. It’s not cheap but it’s really expensive to have to go back in and do it twice. I agree by todays standards.. Back in the day ..Common TopEnd |
| r_towle |
Dec 26 2024, 12:46 PM
I will simply put an option out there.
If it’s not an amazing amount of smoke, driving it and enjoying it may be worth it. |
| technicalninja |
Dec 26 2024, 01:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
I will simply put an option out there. If it’s not an amazing amount of smoke, driving it and enjoying it may be worth it. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I get the "It's burning too much oil" all the time on normal appliance cars. Rebuilding the engine is NEVER a cost-effective way to go. Simple math shows an engine burning a quart over 500 miles equals 200 qts of oil over 100K. Cheap oil is $5 per qt. So, $1000 or $4k+ And, most of the time, the 200K POS will NOT be with the owner for another 100K... I say, "Burn the oil and save up money for another C.A.R . unit." I did my last "stock only" build about 10 years ago... Now, weak rod bolts/bad shit inside the case would worry me MORE than oil consumption. Seeing these old threads with new comments is good for education (especially mine!). Mepstein's thoughts alone have been illuminating! (IMG:style_emoticons/default/first.gif) |
| porschetub |
Dec 28 2024, 10:25 PM
3.2’s have undersized rod bolts. If you use stock rods, you always upgrade the bolts to ARP. We rarely do just a top end. We can’t “warranty” the rebuild without splitting the case. Who knows what else is wrong. Intermediate shaft bearing, main bearings, issues with the fuel pump, etc. Every time we open one up, there’s always something that makes us say that we are glad we split the case. It’s not cheap but it’s really expensive to have to go back in and do it twice. I certainly understand the need for the engine to be suitable for resale , thanks for the info I had no idea of this issue ,cheers. |
Lo-Fi Version | Time is now: 1st April 2026 - 07:07 PM |
