Lost a cylinder, Car is missing bad |
catsltd |
Aug 26 2015, 03:52 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Been working steadly on fixing my 1974 1.8L.
New injectors,plugs,Petronic point replacemnt.etc. Driving to the store when all of a sudden something happened. Car felt like it had dropped 1 of the cylinders. Car does not rev at all,made it home and parked it. Diid a compression test (cold),110 110 100 90. Not happy with 90 on cylinder 1 but felt at least like motor should still be running. Where do I go next.???? I have a dual vacuum line throttle body,and a single vacum on my for sure non stock distributor that had a 4500 RPm rev limiter. (Distribitor mark for cylinder 1 is 180 degrees out.) Like I said I put on a pertronic 1847 and a petronic blaster coil and 8MM wires. I am thinking its a spark think,but really dont know what to do at this point. I have ordered a Mallory Unilite distribitor(4554101),but wont install it till I figure this out. Hoping for some help from you guys. Thanks Grant. |
Series9 |
Aug 27 2015, 04:42 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I have found an infrared thermometer to be extremely useful in diagnosing both dead cylinders and fuel ratio problems.
Start then engine and aim the laser pointer at the header near the exhaust port. You can deduce a lot in a short time. Attached image(s) |
Spoke |
Aug 29 2015, 05:51 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I have found an infrared thermometer to be extremely useful in diagnosing both dead cylinders and fuel ratio problems. Start then engine and aim the laser pointer at the header near the exhaust port. You can deduce a lot in a short time. (IMG:style_emoticons/default/agree.gif) Good to hear you found the issue. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:59 AM |
