D-jet L-jet engine miss fix, Dont be fooled by what you see. |
catsltd |
Aug 30 2015, 08:43 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Just a quick help for people trouble shooting a miss on a injector car.
In the first picture you can see the injector plug looks pretty normal. Thats how it looked when it was in the car. In the second picture this is the same plug cut from my harness. You can see the difference. This happens if your harness plug is bent. But even more crazy is I put in a piece of wire when I was trying to clean it,and it slid right back. So what ever is holding the connector in place has broken,or something. So even if it looks good looking at it,the second I plug it in it will slide back and sometimes the car ran perfect and then 10 minutes later it would start to miss on that cylinder. This was found out thanks do Dave darlings help in another thread I had started. Anyway this is for someone like myself having a fit with random misfire,hope it might help. Attached thumbnail(s) |
SLITS |
Aug 30 2015, 08:48 AM
there is a little tang on the connector. If it is flat or broken off, the connector will slide right out of the plastic holder. If flat, you can bend it up and it will secure the connector in the holder. If broken ................
catsltd |
Aug 30 2015, 09:31 AM
there is a little tang on the connector. If it is flat or broken off, the connector will slide right out of the plastic holder. If flat, you can bend it up and it will secure the connector in the holder. If broken ................ Thanks for that. I did notice the gap between the connector is wider one 1 side as well. I have installed new injectors,so changing out all the connectors will eliminate future problems. Looks like the engine had a fire,so I have a lot of things that I would like to redo. |
JeffBowlsby |
Aug 30 2015, 10:11 AM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So why did you find it necessary to cut the entire harness plug off and not just replace the wire terminal?
That is an L-Jet connector BTW. Found on 1974-75 1.8L 914s, the D-Jet cars are different. |
catsltd |
Aug 30 2015, 06:06 PM
I am replacing the plugs and connectors,not interested in trying to fix it.
The new connectors look much better than my 40 year old ones. Cheers. |
Lo-Fi Version | Time is now: 5th May 2024 - 07:37 AM |
