gas pouring out of this hole. what's missing? |
iankarr |
Aug 30 2015, 02:36 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Was driving along today and started smelling gas. Good thing I pulled over right away cause gas was gushing out of the hole circled in yellow. It's a Weber 44 IDF. Looks like a screw or plug is missing, but I can't seem to find it on a schematic. Any ideas? Thanks! |
VWTortuga336 |
Aug 30 2015, 02:39 PM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
That hole should be plugged, just like the one to the left of it is.
iankarr |
Aug 30 2015, 02:46 PM
I found the plug in the engine compartment. Not sure if it's re-usable...and, if so, how to put it back so I don't blow myself up in the future. Thanks for your help!
VWTortuga336 |
Aug 30 2015, 02:53 PM
I believe those plugs are made of lead. You should be able to just press it back in. You can take a punch and peen it to swell it in the bore.
ejm |
Aug 30 2015, 03:10 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
If that one fell out it's only a matter of time before the other 3 do the same thing. The permanent fix is to replace them with threaded plugs just like is done with the engine oil galley plugs that tend to pop out.
Mark Henry |
Aug 31 2015, 07:12 AM
I'd be careful with tapping and pipe plugs, that is a weak area, don't over torque them.
I'd put the plugs in barely tight and let loctite 620 do the holding. Another option is to peen the plug back in and then JBweld/epoxy over top. But carb will need to come off and the casting has to be super clean for the epoxy to stick. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 AM |
