Electrical trouble shooting help needed for L-jet, Who has the schematic charts in large size and print? |
DRPHIL914 |
Sep 1 2015, 06:46 AM
i asked this question in my new thread for the revival of my recently acquired 75 l-jet 1.8 but apparently it is not getting read so I will post this new thread in hopes of a response.
I need to try and see if this car will run, but before I try and fire it up I , there is some wiring to do, like re-attach all of the gauge wires- the DAPO(not you, Bill) that pulled the wires to paint the car, which never got done, left the wires on the floor of the car - all of the wires from the gauges and the lights in front were pulled to the cabin because he was going to restore it but abandoned the project. nothing is marked or labeled. the dash was pulled out and gauges are in a box!! do I need to re-attach all the gauges to even try to start the car? it appears the ignition is still wired up at from what I can see. I had also read that someone had a large layout of the schematics for the car, that would help going forward as well. thanks for the help. Phil |
DRPHIL914 |
Sep 1 2015, 06:48 AM
What a mess! Is it as bad as it looks?
Attached thumbnail(s) |
blackmoon |
Sep 1 2015, 08:21 AM
Member Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None |
PM me with your email I have a clean copy for the 75 wiring diagram in a PDF format
DRPHIL914 |
Sep 1 2015, 08:37 AM
pm sent
Sep 1 2015, 08:59 AM
The 74 diagrams that Pelican has will work reasonably well for a 75, as well. Plus there are copies of the factory diagrams floating around on line in various places.
The 74+ diagrams are not so good at telling you where in the car the wires go. They are intended to help troubleshoot wiring that is already in the car, so they are built to show the circuit and the current flow, rather than the actual positions of the wires. Sir Andy has a thread in the "classics" forum (I think) that shows his adventure re-wiring his car. Very much worth a look! --DD |
DRPHIL914 |
Sep 1 2015, 09:08 AM
as far as the dash wiring is concerned I should be able to pull my other gauges and use them as a reference, so that may help as well, at lease to get the dash re-wired up.
i've tried searching google with out success. does anyone make a replacement harness? |
Grump |
Sep 1 2015, 09:31 AM
Member Group: Members Posts: 167 Joined: 26-April 06 From: Charlottesville Va. Member No.: 5,930 Region Association: None |
http://www.914world.com/bbs2/index.php?showtopic=13582
This thread worked well for me. I also had the wiring in a bag since the po was going to change color. I obtained the correct diagram with color, from the same source that is sending it to you I think, had it blown up by a copy service and had it laminated. After a time it all starts to make sense, I used dry marker to write on the laminate. Be careful with the colors, they fade in time. Good luck. Bill |
Grump |
Sep 1 2015, 10:10 AM
http://bowlsby.net/914/Classic/TechNotebook.htm
https://www.type4.org/manuals/ljet/ Valuable resources also. Bill |
Lo-Fi Version | Time is now: 17th May 2024 - 03:02 PM |
