Pertronix, Anyone have issues with them? |
DBCooper |
Sep 21 2015, 06:44 AM
+1 - It isn't the Pertronix, it's you.
Customary practice in servicing VW engines with traditional points is to use the ignition to set timing, to find top center when adjusting valves, leaving the ignition on to troubleshoot, or to run some accessory, ALL of which will kill solid state ignition. So stop doing that. And yes, Pertronix will function normally with a Bosch blue coil. |
catsltd |
Sep 21 2015, 07:17 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
+1 - It isn't the Pertronix, it's you. Customary practice in servicing VW engines with traditional points is to use the ignition to set timing, to find top center when adjusting valves, leaving the ignition on to troubleshoot, or to run some accessory, ALL of which will kill solid state ignition. So stop doing that. And yes, Pertronix will function normally with a Bosch blue coil. I have the Igniitor 2 I just bought from Pelican,which I would sell you,Not used. I bought the Mallory,so dont need it. I have the ignitor 1 in my 1.8L and love it,bought my advance is not working so I am going to install the unilite. Let me know,I could save you a couple bucks from list price. Grant |
era vulgaris |
Sep 21 2015, 08:43 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Leaving the key on and ruining the unit....?? is this a wives tale or fact or is it really cause people run the wrong coil or other reasons,never happened to me,can someone prove it. RTFM!!! If you don't know what that stands for, look it up! (IMG:style_emoticons/default/wink.gif) Look at the FAQ on page 2 http://www.pertronix.com/support/manuals/p...nitor12vpos.pdf |
Lo-Fi Version | Time is now: 20th May 2024 - 03:52 AM |
