xperu |
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None ![]() ![]() |
I am asking for some help from the body repair guys on the forum. I had some body work done on my 74 and in doing so we found about 5/8" thick of bondo filler on spot about 10" square. We cut through this area of bondo, did the required repairs and welded the cut area. So, there in about a 1/2' wide area at the weld line.
I am an amateur at bondo, and I can read the instructions, but I would like to hear from you guys on any tips, tools or methods. Thanks. Mike (IMG:style_emoticons/default/confused24.gif) |
JoeDees |
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None ![]() |
Use as little as you possibly can. Extra metal work pays off in the long run.
JoeDees |
And pictures would be extremely helpful.
914Mels |
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California ![]() |
Resist the urge to stir in the hardener, use a putty knife or plastic applicator in a flat sweeping motion to mix. mix on a nonporous surface, cardboard will absorb the catalyst, a flat piece of plastic or old window glass works great. Use acetone to clean up your tools. Shave off the outer layer before it gets rock hard, you'll save a lot of sanding time. Make sure the metal is clean and has some roughness for the bondo to get a bite on. Don't put bondo over paint.
Grump |
Member ![]() ![]() Group: Members Posts: 167 Joined: 26-April 06 From: Charlottesville Va. Member No.: 5,930 Region Association: None ![]() |
YouTube has many video's on how to use bondo.
Bill |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,011 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) If you post some photos of the metal after you remove the filler we may be able to give you some positive suggestions.
Start with correcting the poor metal work. Nothing will give you more pleasure than successfully welding and finishing a metal repair. Take your time and you may be able to skip the filler all together. Here is a place to start. http://www.914world.com/bbs2/index.php?showtopic=107923 Or if you have lots of welding and don't want to make a life time project out of it, Some filler is ok as long as the metal work is very close. http://www.914world.com/bbs2/index.php?sho...c=51775&hl= |
Lo-Fi Version | Time is now: 8th July 2025 - 10:57 AM |
