Problem with a hub bearing replacement |
db9146 |
Sep 5 2015, 08:27 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I haven't had to do this before so on a steep learning curve here.
I completely removed the trailing arms so that I could install new hub bearings and trailing arm bushings at the same time since the drivers side had started to pop. What I found was black Weltmeister bushings on the driver's side and white teflon bushings on the passenger side. I purchased two FAG bearings some time back getting ready for the job. Passenger side one went in ok with a press. Got that side back together and all is good. When I got the bearing in on the driver's side, it seemed just a little loose. I made a call and was told that once I inserted the axle and tightened up on the castle nut to the 220 or so, any play would be taken up and all would be well. Well, it wasn't. Got it all back together, bled the brakes, torqued the wheel and grabbed it to celebrate my success and "?".....what? A slight movement. I rocked the wheel at 3 and 9 and sure enough, there was a very slight movement in the wheel....made more noise that actual movement but it was in the bearing. No doubt about it. So, I broke everything apart on the driver's side and out came the trailing arm, pressed out the hub, pressed out the bearing and am ready to do it again....for the third time on a car with two trailing arms (you do the math). (IMG:style_emoticons/default/dry.gif) I am going to try it again this morning. Anyone had this problem? Could I have damaged the bearing installing it with a press or pulling the hub in with threaded rod? The only bearings I can get locally last night were National brand. When you take it our of the box, the two halves do seem looser than I remember the FAG bearings being....of course, I didn't pull on them much. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:36 AM |
