New build 72 914., Going to be an outlaw Suby engine trans swap. |
Smallblockbug |
Sep 6 2015, 12:24 PM
No talent hack Group: Members Posts: 39 Joined: 26-July 15 From: Yorkville NY Member No.: 19,001 Region Association: North East States |
New project. It will be a slow process unless I sell al my Vw bug stuff and Vw rabbit stuff.
914forme |
Sep 6 2015, 02:20 PM
Okay sounds good, so what do you need liberated to speed this up. Thats not a dual cab in the back ground is it?
pdlightning |
Sep 6 2015, 05:51 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
Pat Garvey |
Sep 6 2015, 06:09 PM
Smallblockbug |
Sep 7 2015, 04:54 PM
It's a 72 vin. The bus in the background isn't mine. I have a 62 pan pa title not in my name $250. Adjustable link pin beam drum to drum $250. 15x7 wide 5 rims $300 never been mounted other then to set on a drum. Old school drag swing axle transmission $150. Crossover exhaust $80. Set of wide 5 drums ready to go with bearing for front drums $80. Or $900 all. Located at 13495 yorkville ny. Until everything sells I get to just look at the car. I also have a little bit of rabbit stuff as well.
Smallblockbug |
Sep 7 2015, 04:55 PM
The pics were taken at the house in Nc where I bought it at.
jimkelly |
Sep 7 2015, 05:14 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
there are some amazing suby build threads here. some are linked in my signature.
Smallblockbug |
Sep 7 2015, 05:21 PM
Same jim Kelly from volksrods days. I've been reading up on a lot of suby builds lately.
jimkelly |
Sep 7 2015, 05:27 PM
nope. but if you found my lost cash, then YUP : ))
Smallblockbug |
Sep 7 2015, 05:30 PM
Lol. Just checking as he was a metal working guy on there years ago. Use to stretch ghia fenders to fit wide tires. I'm sure I will be around off and on depending on cash flow.
rhodyguy |
Sep 8 2015, 08:55 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That was 'john' Kelly.
Smallblockbug |
Sep 9 2015, 06:05 PM
Yep john kelly is his name. Got messed up.
Smallblockbug |
Sep 9 2015, 06:15 PM
Step 1 remove trim and vinyl. Step 2 figure out what is the best way to smooth it all out.
Attached thumbnail(s) |
Smallblockbug |
Sep 10 2015, 08:23 PM
Some more searching for rust.
theleschyouknow |
Sep 10 2015, 09:21 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
Step 1 remove trim and vinyl. Step 2 figure out what is the best way to smooth it all out. interesting under the targa vinyl what's the original color? (IMG:style_emoticons/default/beerchug.gif) cjl |
Smallblockbug |
Sep 11 2015, 04:58 AM
Its green. The red was done in the past at some point.
Smallblockbug |
Sep 20 2015, 06:11 PM
Found rust but it was expected. Nothing out of my realm of expertese. Just need to sell my bug parts to get the project off the ground.
Lo-Fi Version | Time is now: 9th May 2024 - 11:18 AM |
