Shift rod for -6 with headers, The length ,straight or bent? |
porschetub |
Sep 15 2015, 02:27 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
bcheney |
Sep 15 2015, 04:11 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
My shift rod has been modified by the PO and is largely straight until it gets near the g/box,the welding leaves a bit to be desired so I would like to tidy it up,but first I need to know if it's correct. My exhaust set up as purchased from PO. Thanks. Rich Johnson modified mine. Here is what it looks like. I have a side shifter with MSDS type headers. Rich has done many of these and will be a great source of information to help you. You can email him : a914guy@aol.com or you can find him in our Vendor Forum and send a (PM) private message Attached image(s) |
gereed75 |
Sep 15 2015, 08:35 AM
Senior Member Group: Members Posts: 1,247 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I have the same (or similar) headers and identical setup (side shifter). I believe that my shift rod is a straight tube with no coupler at the back. I will check this afternoon to verify.
Sweet looking car !! |
Dave_Darling |
Sep 15 2015, 09:14 AM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Does what you currently have work with your current setup? If so, make a jig from it so you can get everything back in that place, and re-weld using the jig. Don't try to re-invent the wheel.
--DD |
porschetub |
Sep 15 2015, 01:09 PM
Does what you currently have work with your current setup? If so, make a jig from it so you can get everything back in that place, and re-weld using the jig. Don't try to re-invent the wheel. --DD The hoist pic is taken when the PO had his 3.0 in there,the rod was never fitted as you can see,I have seen a pic of one of Brads (914ltd) and its straight ???. The path from the tunnel rod to the gearbox is anything but straight so I'am thinking the offsets are required,I could bend the offsets into mine but it will then be too short....what to do?. |
porschetub |
Sep 15 2015, 01:14 PM
My shift rod has been modified by the PO and is largely straight until it gets near the g/box,the welding leaves a bit to be desired so I would like to tidy it up,but first I need to know if it's correct. My exhaust set up as purchased from PO. Thanks. Rich Johnson modified mine. Here is what it looks like. I have a side shifter with MSDS type headers. Rich has done many of these and will be a great source of information to help you. You can email him : a914guy@aol.com or you can find him in our Vendor Forum and send a (PM) private message Thanks ,that's the pic I was looking for, now that I have the length I've got something to go on. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:17 AM |
