tach, wire |
tach, wire |
cpavlenko |
Sep 16 2015, 12:48 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
where is the tach wire in engine compartment.
914Mels |
Sep 16 2015, 12:54 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
should be in the harness going to the coil.
cpavlenko |
Sep 16 2015, 12:55 PM
zipedadoo |
Sep 16 2015, 01:27 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
From what I've read it's the tach itself.
What part of Arizona do you live in? I live near Show low. Be nice to have another local teener. |
cpavlenko |
Sep 16 2015, 01:31 PM
Sep 16 2015, 07:52 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Could also be the points, condensor, distributor ground, or wiring. But the tach itself is the most likely problem.
--DD |
porschetub |
Sep 16 2015, 07:57 PM
Purple/black from tach to 14pin on relay board from memory,don't know if it stays that colour from engine 12pin harness to coil .
Check the connection/condition of the wires at as many points as you can also check you a good earth on the back of the tacho and have full 12volts going to it (red/white wire). Failing that get it repaired or fit good secondhand one, the cost to repair could be up there. |
cpavlenko |
Sep 16 2015, 08:23 PM
Thanks for all the info guys, I'll check it all out tomorrow. I really like 914world for all the great input i get back, thanks. (IMG:style_emoticons/default/beerchug.gif) oh, I'm not using points.
Lo-Fi Version | Time is now: 8th May 2024 - 10:09 PM |
