Door Lock Won't Lock/Unlock With Key, Broken tumbler tab |
jack20 |
Sep 17 2015, 04:44 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Hello,
Attempted to lock my door with the key and there was no resistance. I pulled the door handle and found that one of the tabs on the end of the tumbler that indexes with the lever had worn off. Does anyone know if tumbler assemblies are available and do they cross reference to a VW part? Thank you, Jack |
914Sixer |
Sep 17 2015, 05:40 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
911 & 914 are interchangeable. VW will not work
TheCabinetmaker |
Sep 17 2015, 05:46 PM
Do you have a pic of the part you need?
TheCabinetmaker |
Sep 17 2015, 05:47 PM
Sorry, my second ever double post.
JRust |
Sep 17 2015, 06:06 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Hello, Attempted to lock my door with the key and there was no resistance. I pulled the door handle and found that one of the tabs on the end of the tumbler that indexes with the lever had worn off. Does anyone know if tumbler assemblies are available and do they cross reference to a VW part? Thank you, Jack So you need the complete cylinder right? Or the end piece that attaches to the cylinder? Either way I'm happy to ship you either part. At Red Rocks so it would be next week. Shoot a pic to be sure & post it. then get me your address (IMG:style_emoticons/default/smile.gif) |
jack20 |
Sep 17 2015, 07:14 PM
Sep 17 2015, 07:32 PM
Stick the key into that tumbler.
All wafers need to be flush with the key in place. Using a Dremel, grind down the wafers that are sticking up, Clean it all with a good carb cleaner or alcohol and fed rid of all the graphite Lube with light oil Put it back into the housing, should work |
TheCabinetmaker |
Sep 18 2015, 06:06 AM
Hard to see in the pic, but the cam looks to be fine. It only has that one tab. You'll need to pull the wafers and clean then relube. Pull the wafers one at a time and place them carefully in order so they go back in the same slots. Notice the two sets of slots are offset from each other. Carefully pull the 10 little springs and put them in a small container of lacquer thinner or acetone. Clean the wafers one at a time. Put it back together. In that same small container add some powered graphite them mix in some more thinner. The graphite will be suspended in the thinner, but not dissolved. Soak the cylinder in the thinner then take it out. The thinner will evaporate leaving a thin coat of graphite without gumming it up. If you need parts, pm me.
jack20 |
Sep 18 2015, 10:15 AM
Hard to see in the pic, but the cam looks to be fine. It only has that one tab. You'll need to pull the wafers and clean then relube. Pull the wafers one at a time and place them carefully in order so they go back in the same slots. Notice the two sets of slots are offset from each other. Carefully pull the 10 little springs and put them in a small container of lacquer thinner or acetone. Clean the wafers one at a time. Put it back together. In that same small container add some powered graphite them mix in some more thinner. The graphite will be suspended in the thinner, but not dissolved. Soak the cylinder in the thinner then take it out. The thinner will evaporate leaving a thin coat of graphite without gumming it up. If you need parts, pm me. Thanks for the detailed response Curt. I'll clean it up,as you described. What's happening is if I hold the lever in place and turn the key back and forth, as if to lock and unlock the door, it feels stripped in the unlock motion and functional in the lock motion. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:59 PM |
