LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
904svo |
Sep 18 2015, 01:06 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Porsche used relay logic to operate the fog lamps, they used the low resistance of the high beam light to ground to the fog light relay. The fog lamp switch with supply battery to the other side of the relay to turn on the fog lamps when the high beams were turn on battery would be on both sides of the fog light relay this would cause it to release. I think with your arrangement you added relays for your new lighting system and the low resistance ground is now missing causing a feed back problem.
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 PM |
