LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
orthobiz |
Sep 19 2015, 02:37 PM
Wow, incredible answer Dave! I'm gonna try to wade through it. All I seem to remember is V=IR from high school...
BTW, all I did was unplug the headlight connector from my old headlights and then I plugged the new headlights in. It's a 3 prong connector and there is only one way it will fit in. What I'd really like to do is uncouple the fog lights from the headlights. Which probably means disconnecting some kind of wire somewhere. Wiring diagrams are great but where are the specific relays located in the car? (I think under the dash) Paul |
Lo-Fi Version | Time is now: 17th May 2024 - 03:17 PM |
