LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
Mike Bellis |
Sep 20 2015, 12:20 AM
There is no way the fog lamp power circuit can effect the high or low beam power circuit. They are completely separate circuits.
The only connection is the high beam providing ground to the fog light relay when off and the headlight switch providing power when on. The load side of these circuits are isolated. There must be some wiring messed up somewhere. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:52 PM |
