LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
john77 |
Sep 20 2015, 06:11 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Are you sure it doesn't already have the JWest fog light module? My car has it and I have the GE nighthawks too. Once I plugged the nighthawks in my lights started doing all sorts of crazy things. If I turn the fogs on the fogs don't come on but it switches the nighthawks to high beams. I just stopped using my fogs, and as soon as I get around to it I plan on removing the JWest module.
Lo-Fi Version | Time is now: 17th May 2024 - 04:50 PM |
