LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
904svo |
Sep 21 2015, 06:24 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Try this. On fuse#1 there is 2 white/blue wires (one goes to High beam light the other to the fog light relay) cut these two wires apart find out which one goes to
the High beam light ( apply battery) reconnect this to fuse#1 with a new spare wire. Connect this wire to terminal #85 on a new relay. The Blue/white wire left over attach to a new relay terminal #30 . Connect terminals #86 and #87a together and run to ground. This fix will supply ground to the fog light relay on when the low beams headlight are on and remove it when the high beams are turn on. |
Dave_Darling |
Sep 21 2015, 09:03 PM
Connect this wire to terminal #85 on a new relay. The Blue/white wire left over attach to a new relay terminal #30 . You don't need to do that. If you want the fogs on only with the low beams, just move the "left over" white/blue wire to one of the low beam fuses. You can use a "piggyback connector" do do that relatively painlessly. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 03:07 PM |
