LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
Chi-town |
Apr 1 2019, 02:11 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Spoke |
Apr 1 2019, 04:00 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Easiest way It could be so that this wire is found on the lugs on the fuse panel for fuse 1 or 2. Easily removed and with a pigtail with male spade on one side and ring terminal on the other side, the modification "should" be an easy update. The fogs would be on then with low or high beam. Talking to Bruce today, I realized my 930 with LED headlights has the same connections as the 914. I haven't tried the foglights with the LED headlights to see if they still work. Will have to try it this weekend. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:37 PM |
