LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
Shredhead |
Apr 10 2019, 12:49 PM
Member Group: Members Posts: 110 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
I wonder if this would solve the problem I have, which I really haven't tried to solve yet. Have new LED headlight bulbs. First time I tried them, High Beam, check, Low Beam, check. Can't recall if I tried the fogs, which are still incandescent (and I think one is out). Next time I tried, them, Highs worked fine, Lows... nada.
bdstone914 |
Apr 10 2019, 09:41 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I wonder if this would solve the problem I have, which I really haven't tried to solve yet. Have new LED headlight bulbs. First time I tried them, High Beam, check, Low Beam, check. Can't recall if I tried the fogs, which are still incandescent (and I think one is out). Next time I tried, them, Highs worked fine, Lows... nada. @Shredhead You may have a hi-low relay that is sticky. Bruce |
Lo-Fi Version | Time is now: 17th May 2024 - 05:02 PM |
