LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
Spoke |
Apr 12 2019, 07:25 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
3) "1974, 1975, USA and except-USA" White/Blue wire connected to Fuse 1. Foglight relay is J12. Note wire on pin 86 on J12 foglight relay connecting to Fuse 1.
Also note that in previous years, it was pin 85 used as the switched ground for the foglight relay. Here it is pin 86. For those questioning whether a relay coil could be powered one way or another, looks like Porsche answered that question... Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 PM |
