LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
904svo |
Sep 21 2015, 06:24 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Try this. On fuse#1 there is 2 white/blue wires (one goes to High beam light the other to the fog light relay) cut these two wires apart find out which one goes to
the High beam light ( apply battery) reconnect this to fuse#1 with a new spare wire. Connect this wire to terminal #85 on a new relay. The Blue/white wire left over attach to a new relay terminal #30 . Connect terminals #86 and #87a together and run to ground. This fix will supply ground to the fog light relay on when the low beams headlight are on and remove it when the high beams are turn on. |
orthobiz |
Sep 21 2015, 07:46 PM
Try this. On fuse#1 there is 2 white/blue wires (one goes to High beam light the other to the fog light relay) cut these two wires apart find out which one goes to the High beam light ( apply battery) reconnect this to fuse#1 with a new spare wire. Connect this wire to terminal #85 on a new relay. The Blue/white wire left over attach to a new relay terminal #30 . Connect terminals #86 and #87a together and run to ground. This fix will supply ground to the fog light relay on when the low beams headlight are on and remove it when the high beams are turn on. Sounds doable! I think what I really want to do is have the fog lights work whenever I pull out the fog light switch. I will never run them with the brights, I just don't want to worry about the fog lights being triggered by anything other than me pulling out the dash switch! Paul |
904svo |
Sep 21 2015, 09:02 PM
Try this. On fuse#1 there is 2 white/blue wires (one goes to High beam light the other to the fog light relay) cut these two wires apart find out which one goes to the High beam light ( apply battery) reconnect this to fuse#1 with a new spare wire. Connect this wire to terminal #85 on a new relay. The Blue/white wire left over attach to a new relay terminal #30 . Connect terminals #86 and #87a together and run to ground. This fix will supply ground to the fog light relay on when the low beams headlight are on and remove it when the high beams are turn on. Sounds doable! I think what I really want to do is have the fog lights work whenever I pull out the fog light switch. I will never run them with the brights, I just don't want to worry about the fog lights being triggered by anything other than me pulling out the dash switch! Paul If you want that option, take the Blue/white wire and put it to ground instead of wiring it to #30 , forget about the rest of the wiring and relay. |
raynekat |
Feb 12 2021, 12:21 AM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
If you want that option, take the Blue/white wire and put it to ground instead of wiring it to #30 , forget about the rest of the wiring and relay. Started to have the same wonky high beam/fog light issue a year after installing my 914 Rubber LED bulbs. At first, everything worked correctly. Just recently, no fogs when I pull the fog light switch and instead the high beams come on. So I just took the white/blue wire from the fog light relay and removed it from the other relay and went directly to ground with it. Everything works the way I want it now. This change makes the fogs independent of the headlight/high beam switches. Can run the fogs on their own or with any combination of low/high beams. Simple. One thing I noticed was I had a couple of bad relays. I think somehow the LED headlights are back feeding power into this fog light relay and frying them. Had two bad ones I was trying to get working. Bench tested them and both were inoperative. Made the wiring changes above, and inserted new relay and was back in business. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:50 PM |
