Engine tin, Air duct floor interference with shift rod |
jsaum |
Sep 18 2015, 10:11 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I'm having an issue with the drivers side engine tin that covers the shift rod on my side shifter trans. After installing the bottom drivers side engine tin I found that it was touching the shift rod and I couldn't shift into reverse or first gear. I have a 1.8 with SS exhaust, since the shift rod is locked into place with the conical screws the only adjustment place I see is at the shift lever. I'm also using a short shifter. Has anyone run into this problem before? How close does the engine tin normally come to the shift rod?
Thanks, Jsaum |
914Sixer |
Sep 18 2015, 04:30 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Thinking bent shift rod.
Sep 18 2015, 05:43 PM
Please post pic of tin.
There are two types. |
Sep 18 2015, 06:26 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Yup, probably has an early piece of tin. The ones for the tail-shift transmissions bend down to go under the shift rod, the ones for the side-shift transmissions bend upward to go over the shift rod. Using the wrong one will cause interference.
--DD |
jsaum |
Sep 20 2015, 11:44 AM
I must have the early tin here's a picture. Does anyone have a picture of a letter one? Thanks,
Jsaum Attached thumbnail(s) |
stugray |
Sep 20 2015, 12:33 PM
Strange I converted from tail to side shift and had no interference.
I also do not recognize that engine tin. Maybe I am missing one. Can we get a pic of it on the car? |
TheCabinetmaker |
Sep 20 2015, 12:36 PM
That's an early side shift tin. It goes over the rod. Is your car a 74?
jsaum |
Sep 20 2015, 01:27 PM
My car is a 72, I converted it to the side shifter trans. Looks like I need the later tin.
Sep 20 2015, 07:34 PM
Yup, you need the later side shifter tin.
Place a WTB in the classifieds or as Bruce Stone or Garold Shafer |
ndfrigi |
Sep 20 2015, 08:05 PM
jsaum |
Sep 20 2015, 08:14 PM
If you remove that tin and your shifting is doing fine, just remove that or maybe find a replacement for that tin. I believed that is basically part of the heater tins. Currently, I don't have that tin installed but my car is running well. Thanks, yes I did take it off. Now I'm looking for one just because I like to keep things as stock as possible. I'll probably never tell any difference in the way the cars runs. |
Lo-Fi Version | Time is now: 9th May 2024 - 04:55 AM |
