To repair or not |
To repair or not |
mckeedad6 |
Sep 18 2015, 10:46 AM
Newbie Group: Members Posts: 40 Joined: 15-September 15 From: Imlay City, MI Member No.: 19,161 Region Association: Upper MidWest |
Ok Guys. I have decided to sell my uncles 74 914. Question is how much more would it be worth if I replaced the rear trunk floor. Would it add that much extra value or should I leave it as is for next owner to deal with. This is the only bad rust on the car all other trouble spots are clean and solid. thanks for your help.
Attached thumbnail(s) |
Spoke |
Sep 18 2015, 11:13 AM
Can't really tell how much rust is there. Are there pin holes or larger? Are you or a friend/family going to repair it? It may cost $500+ to repair it. Not sure if you'll get the value out of the sale.
If the rest of the car is in good shape, that should carry a good price. These cars are 40+ years old; none are perfect. |
BK911 |
Sep 18 2015, 11:17 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
From the pictures, it looks like a wire wheel and some POR-15 should do the trick.
mckeedad6 |
Sep 18 2015, 11:21 AM
Can't really tell how much rust is there. Are there pin holes or larger? Are you or a friend/family going to repair it? It may cost $500+ to repair it. Not sure if you'll get the value out of the sale. If the rest of the car is in good shape, that should carry a good price. These cars are 40+ years old; none are perfect. there are some bigger holes. Biggest is maybe quarter size and where the floor meets the back has a gap that was covered from the factory caulk. not really to bad considering the others I've seen. It looked better before I wire wheeled it. I can do repairs myself. I was thinking putting a new rear pan in it. Just didn't know if i't would be worth fixing just to sell it. Thanks for responding |
scotty b |
Sep 18 2015, 11:39 AM
a proper repair is going to cost more than you will gain by doing it. A cover up will turn prospective buyers off for god. If you want to try for a couple extra bucks, cut it all out and get it prepped for a new panel. I for one would rather see it all cut out and cleaned ready for repair, than the swiss cheese it currently is. Otherwise leave it be and take what you can get.
mckeedad6 |
Sep 18 2015, 11:42 AM
a proper repair is going to cost more than you will gain by doing it. A cover up will turn prospective buyers off for god. If you want to try for a couple extra bucks, cut it all out and get it prepped for a new panel. I for one would rather see it all cut out and cleaned ready for repair, than the swiss cheese it currently is. Otherwise leave it be and take what you can get. Thanks. Any idea on the negative effect it should have on price? Just curious. |
scotty b |
Sep 18 2015, 11:47 AM
a proper repair is going to cost more than you will gain by doing it. A cover up will turn prospective buyers off for god. If you want to try for a couple extra bucks, cut it all out and get it prepped for a new panel. I for one would rather see it all cut out and cleaned ready for repair, than the swiss cheese it currently is. Otherwise leave it be and take what you can get. Thanks. Any idea on the negative effect it should have on price? Just curious. a proper trunk repair from a good shop is going to run 1500-2000.00 parts and labor. That is all depending on the shops rate, how perfect you want it done, and what may lie under the known issue. I would suspect someone looking to do it themselves might want to knock 500.00 +or- off |
scotty b |
Sep 18 2015, 11:51 AM
FWIW by proper repair, i mean :
removing the old section, sandblast and etch priming the exposed metal, hammer and dolly any distortion, fit the new panel, spot weld it back in, hammer and dolly any new distortion, sand and prime the whole lot, replace the cover piece in the center, swap the old stamped number over, seam seal and paint |
mckeedad6 |
Sep 18 2015, 11:57 AM
FWIW by proper repair, i mean : removing the old section, sandblast and etch priming the exposed metal, hammer and dolly any distortion, fit the new panel, spot weld it back in, hammer and dolly any new distortion, sand and prime the whole lot, replace the cover piece in the center, swap the old stamped number over, seam seal and paint That's how I would repair it. Just don't know if I want to spend the time on it for a small gain. Any thoughts on how to price the car. Would like to get a fair price for it. i could pm details if you are willing to help. |
Andyrew |
Sep 18 2015, 12:16 PM
We cant tell you anything on how to price the car without more pics and details. If its just a roller car it probably isnt worth any more than 1k.
It looks like there are some decent sized holes in there. Its a great spot to learn to weld and fix as its not structural, its really easy to get to, and fixing it is fairly easy. You could patch up most of those holes in a weekend if you knew what you were doing. IMHO I would fix it. Some 16ga steel, a wire wheel, a true mig welder, and an air grinder will make quick work of it. Do one patch at a time and patch to good metal. Use tach welds or 1/2" beads. Finish it up with a flap wheel grinder, rust preventative paint (Like Por 15), some primer, maybe some glaze putty if you want and some paint and you've got a nice repair. Note you need to treat and paint the underside as well. |
mckeedad6 |
Sep 18 2015, 12:31 PM
We cant tell you anything on how to price the car without more pics and details. If its just a roller car it probably isnt worth any more than 1k. It looks like there are some decent sized holes in there. Its a great spot to learn to weld and fix as its not structural, its really easy to get to, and fixing it is fairly easy. You could patch up most of those holes in a weekend if you knew what you were doing. IMHO I would fix it. Some 16ga steel, a wire wheel, a true mig welder, and an air grinder will make quick work of it. Do one patch at a time and patch to good metal. Use tach welds or 1/2" beads. Finish it up with a flap wheel grinder, rust preventative paint (Like Por 15), some primer, maybe some glaze putty if you want and some paint and you've got a nice repair. Note you need to treat and paint the underside as well. I was thinking of getting a replacement panel from Restoration Design and repairing it that way. I am going to get pics this weekend and post them. i have some in another post. I didn't know if I could add here. ( I'm new to this forum ) It is far from a roller. It was restored in 94/95 ish motor completely rebuilt and all problem areas fixed. I have receipts to show all work done at that time and new clutch and other maintenance. I am replacing the fuel pump but it runs and drives great. It was restored in Pa and brought to MI for couple years. since 2000 ish it has been in Az just driven occasionally. The trunk is worst part of car. all other parts are solid. Its a 1.8 with original fi still installed and un molested. |
mckeedad6 |
Sep 18 2015, 12:33 PM
GaroldShaffer |
Sep 18 2015, 12:38 PM
You bought another 914? Group: Benefactors Posts: 7,621 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
So it is in AZ now or MI?
mckeedad6 |
Sep 18 2015, 01:56 PM
Sep 18 2015, 07:49 PM
mcMark can help you now, he is in Detroit area....
mckeedad6 |
Sep 18 2015, 07:58 PM
bdstone914 |
Sep 19 2015, 06:56 AM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
mcMark can help you now, he is in Detroit area.... That would be great. Is there a way to get a hold of him or if he pm me i can give him my number. I'll take any help advice I can get. Do you know where in Det area he is? McMark is not in the Detroit area. He is in Grand Rapids area which is the other side of the state. Look for information on Original Customs. |
mckeedad6 |
Sep 19 2015, 07:16 AM
mcMark can help you now, he is in Detroit area.... That would be great. Is there a way to get a hold of him or if he pm me i can give him my number. I'll take any help advice I can get. Do you know where in Det area he is? McMark is not in the Detroit area. He is in Grand Rapids area which is the other side of the state. Look for information on Original Customs. Oh ok. Yeah that's 3 hrs from me. I'll check that out. Thanks |
Harpo |
Sep 19 2015, 07:18 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I recommend you remove the rocker panels and take a look at the longs. I don't believe that McMark will be open for business until the end of the month. I'm about one hr away.
BTW car looks good from the photos David |
jmitro |
Sep 19 2015, 07:27 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
It's hard to believe (seeing what that trunk looks like) there is NO other rust problems on the car. That said, I would probably leave it alone and sell the car as is; you won't recover the cost of a proper repair in your sale.
By that I mean, lets say it costs $1500 for a complete repair of the trunk. And you want (for example) $7000 for the car as is. You'd be hard pressed IMHO to then justify an $8500 price for the car if it was repaired. |
Lo-Fi Version | Time is now: 8th May 2024 - 05:11 PM |
